i need help !
how do i change the name of my website from notepad and also add links to it
Photo of Richard
Richard
  • 1 Post
  • confused
Photo of Nathan
Nathan, Champion
  • 3739 Posts
  • 307 Reply Likes
Hi, Richard! Thank you for using this forum for support!
But, you can't change your website's name from notepad. You change it in the site builder. Here are the Steps:
First, go into the site builder.
Then, next to the list of pages (The drop down box) and it is in a blue square or something, look like this:
Click the "Site manager" tab.
The page looks like this:
Do you see where the site name is? Right below it, there is a link that says "Rename" Click that. Input your new site name and click on "Rename site" (or cancel)
That's it! You renamed your website! You will need to publish your site for these changes to take effect.
Want to create a link? Here are the Steps:
1. In a text widget, highlight the text you want to be a link.
2. In the text editing bar, click on the button "Link" Looks like this:
3. Now, a box will pop up, like this:
4. Choose the type of link. Input the text or click the icon next to it. Then, click "Ok"
That's it! You just created a link! Preview the page now, and when you click it, it should take you to the URL, page, file, etc. specified!
I hope this helps!
Nathan
Photo of Nathan
Nathan, Champion
  • 3739 Posts
  • 307 Reply Likes
I gave instructions, for both, Links and Changing the site name. The Changing site name is the first one, and the Links is the second bold sentence. I just wanted to let you know. And, by the way, Brianna, the Video Tutorials on Yola.tv are great! :)
Photo of Brianna
Brianna
  • 2045 Posts
  • 92 Reply Likes
Thank you, Nathan.
Photo of Nathan
Nathan, Champion
  • 3739 Posts
  • 307 Reply Likes
Your welcome
Photo of Nathan
Nathan, Champion
  • 3739 Posts
  • 307 Reply Likes
That video tutorial is a good source too. It is better to see it in video. I hope I explained it good up there! :)
Photo of Brianna
Brianna
  • 2045 Posts
  • 92 Reply Likes
You did fantastic, Nathan. We greatly appreciate the time and dedication you have put forth to the Yola community. Thank you!
