i need help please
  • In Progress
Hi i purchased a domain name from you guys www.theadvantagecard.co.uk i also built my website through you guys. everything was working fine. then i tried veryfying to google. i am not worried about this what i am worried about is that i does not let me or anyone go on my site it saids that the problem is Unable to locate the server named "www.theadvantagecard.co.uk" --- the server does not have a DNS entry. Perhaps there is a misspelling in the server name, or the server no longer exists. Double-check the name and try again. please i need your help to fix this problem ASAP. Thank you
Photo of danny callow
danny callow
  • 1 Post
Photo of David
David
  • 465 Posts
  • 94 Reply Likes
Danny
I can access your site fine
Photo of Brianna
Brianna
  • 2045 Posts
  • 92 Reply Likes
Thanks for testing this, David. We appreciate your support!
Photo of Brianna
Brianna
  • 2045 Posts
  • 92 Reply Likes
Hi Danny,
I too was able to open up your published site as David has above. Please try clearing your browser's cache and check again whether or not you can open your site. If you are still experiencing troubles, please share the browser version and type you are using.
