I need to add javascript for advertising etc is it possible using yola?
  • Updated 7 years ago
everytime i add java with html widget button it just opens a blank slim box with nothing in it , am i doing something wrong?
Photo of Si Maddocks
Si Maddocks
  • 4 Posts
Posted 7 years ago
Photo of Gop
Gop
  • 7473 Posts
  • 2115 Reply Likes
Hello Si,
It may depend on the complexity of the javascript code and certainly depends on the file headers.
Some javascript needs to be called from another place, generally stored in the file manager if you have Yola Silver. You can also have this hosted externally and call the file from there.
Sanja
In addition to Gop's remarks, sometimes you just need to navigate away from the page and then come back and it may work. Perhaps if you can share your code with us, we might be able to spot if there is anything amiss.
Si Maddocks
  • 4 Posts
thanks Gop , il try hosting it somewhere externally.
Photo of Gop
Gop
  • 7473 Posts
  • 2115 Reply Likes
yourjavascript.com is a popular hosting setup and easily used if you wish to try.
