Menu Problem..
Menus. Please see my website :
http://natanddaveoctober2011.yolasite...
I have added a background image that I quite like. [See that the other tabs have a green background]
But - now you cannot see the menus at the top very well..
Can I change the text colour so that you can see the menu?
or - see I have added another menu as an example - maybe that is a better way forward - but it does not seem to look as good....
anyone have any ideas?
thanks
Photo of vasey888
vasey888
  • 51 Posts
Photo of James
James
  • 75 Posts
  • 2 Reply Likes
Well, you could try this:
Go to "Edit Naviagtion"
Place this code around all of the "navigation" text Section
<font color="#000000">Tab</font>
So
it would be for your one tab as an example
<font color="#000000">Wedding Details</font>
Don't forget to remove the <!-- --> parts though
Photo of James
James
  • 75 Posts
  • 2 Reply Likes
but, that would change the color for all parts of your website, so you might have to move to a color that is viewable for all your background colors
To do that just search on google: hex color chart
and find a color you want and change "000000" in the code with the code it says.
You probably know this, but if you don't thats how.
Photo of vasey888
vasey888
  • 51 Posts
thats superb - thanks so much
Photo of James
James
  • 75 Posts
  • 2 Reply Likes
No problem, ask if you need anything else
