My content locking gateway wont work! Help!
Im an affiliate with BLAM Ads and my site uses their "Content Locking Gateway" and today they stopped working on my site...it works fine with a HTML tester so its not them...It pops up and disappears a second later...any ideas?
Nick
Photo of codman43
codman43
  • 3 Posts
  • mad
Photo of diane
diane
  • 1238 Posts
  • 121 Reply Likes
Hi, codman43,
Can you share your url so we can take a look at what might be happening? Did you add any kind of code recently that may be causing the problem?
Photo of codman43
codman43
  • 3 Posts
No, not that I know of. It's possible that when they updated they put IP bypass the the creator but I think that's optional. I showed one my sites to a friend but the gateway worked then, but on my computer it won't work now. The URL is:
freemcgiveaways.yolasite.com/
Thanks for your time,
Nick
Photo of diane
diane
  • 1238 Posts
  • 121 Reply Likes
Hi, Nick,
I am checking into this. Thanks for your patience as we investigate.
Photo of codman43
codman43
  • 3 Posts
Thank you!
Photo of diane
diane
  • 1238 Posts
  • 121 Reply Likes
Hi, Codman43,
I took a look at your code. There was a missing quote mark which I fixed, but there is an ending < / form > tag without an opening tag. Can you please try recopying the original code and repaste it?
