My widget doesw not fit inside box
  • Updated 4 years ago
hello
I have create a google widget search box and cannot get this to fit inside the widget box provided, would you be able to advise me how to get the widget to fit inside the box provided?
Thanks
Photo of plumpedlipssmokeyeyes
  • 103 Posts
  • 1 Reply Like
  • confused
Posted 7 years ago
Photo of Nathan
Nathan, Champion
  • 3739 Posts
  • 307 Reply Likes
Hello plumpedlipssmokeyeyes
Can you post your Website's URL so I can take a look? Thanks.
Nathan
  • 103 Posts
  • 1 Reply Like
hi, thanks for your reply
my site is not yet published, it looks as though i need to enlarge the frame provided slightly however?
Photo of Brianna
Brianna
  • 2045 Posts
  • 92 Reply Likes
Hello,
Thanks for your message. I would suggest changing your site's layout to a one column layout. While in the sitebuilder, simply press 'Layout' and select '1 Column'. This will allow you the most flexibility while adding widgets to your site and creating the layout that you are seeking. Please note that you can always use the Column Divider Widget to break up areas of your site.
Please let us know if changing the layout of your page helps to achieve the results you are seeking.
  • 103 Posts
  • 1 Reply Like
hi thanks for your reply
i have tried this and reduced the margin on the box below, however the widget still does not fit?
Sanja, Official Rep
Hello plumpedlipssmokeyeyes,
Would you mind sharing your Google search box widget code? You may need to manually adjust the size of this. Please be sure to use <!-- and --> to wrap your code so that they show up on the forum.
  • 103 Posts
  • 1 Reply Like
Get the Google Search Widget (Web & Site Search) widget and many other great free widgets at Widgetbox! Not seeing a widget? (More info)
  • 103 Posts
  • 1 Reply Like
is this it? ^
Thanks
Photo of diane
diane
  • 1238 Posts
  • 121 Reply Likes
Hi, plumpedlipssmokeyeyes,
Can you please use <!-- and --> to wrap your code so that they show up on the forum. <!-- goes at the beginning of the code and --> at the end of the code. Thanks.
Photo of Kristoper Galvez
Kristoper Galvez
  • 1 Post
I have the same problem as well my widget is not fit I can see the whit background and I wanted this to be fix. Can you help me out please? Thanks!
I will post my website so that you can see it.
www.lifestylenurse.com
Thanks for your help.
Kris
Photo of Laura Thomas
  • 4536 Posts
  • 211 Reply Likes
Hi Kris,
This forum is aimed at helping Yola website users. I suggest you contact your website host for help with your display issue. They will likely also need to see the code you are using. If you want to switch to Yola we'd be happy to have you and then we'd be able to assist you further!
