my yola problem!!!
is there any problem whith yola?
my sites dont open in my yola!!!
http://www.vladman.net/
Photo of Rui
Rui
  • 16 Posts
  • 1 Reply Like
Photo of Brianna
Brianna
  • 2045 Posts
  • 92 Reply Likes
Hi vlad.man,
Thanks for bringing this to our attention. I am happy to assure you that I can pull up your site without hesitation. Here is what I see while visiting your site:
Is this the site I am supposed to be seeing? Would you mind sharing the browser version and type you are using?
Photo of Rui
Rui
  • 16 Posts
  • 1 Reply Like
hello yes i am using IE9 the problem is not in browsing is in sitebuilder, i can navigate all the places in ́my yola ́but wen i try open most of the times stays in ́opening page ́ or wen i try to put any widget resuming sitebuilder in very very slow :(
ps-in diferent ip,pc etc.
Photo of Brianna
Brianna
  • 2045 Posts
  • 92 Reply Likes
Hi,
I have just responded to your email request with further information. It appears that you are using a browser version that is not yet supported by Yola - IE9.
Yola currently supports the following browsers:
* Firefox 3 or higher
* Internet Explorer 7, 8
* Safari 3 Beta or higher
* Google Chrome
If you are not using one of the following above supported browsers, then you may experience less than optimal Sitebuilding performance and as a result, our support will be limited. We strongly recommend that you use one our supported browsers. For the best user experience, Yola recommends Firefox.
Photo of Emmy
Emmy
  • 5892 Posts
  • 299 Reply Likes
Hello vlad.man,
I see what the problem is, it's that your site is not loading in the Sitebuilder. Can you please do a few things for me and then let me know if this helps the problem you are having:
1. Clear your browser's cache. This link has more information: Clear your browser's cache.
2. Check your privacy settings. You must accept cookies from Yola. Please click on this link to find instructions for accepting cookies with your browser: Accept cookies.
3. Check that your browser is set to enable Javascript. This link has more information on how to check: Enable Javascript.
4. Try loading the site in a different browser (eg. Firefox, Safari, Internet Explorer). We would suggest using the Firefox browser as this browser seems to work best in the Yola environment. It is a free download if you would like to give it a try: Download Firefox.
5. Try loading the site on a different computer or network if possible.
Please let me know how this goes for you.
Kind Regards,
Emmy
