Need Help
How to edit the html code right before the closing body tag,For integration of infolinks.com In-text ads?
Photo of yabarnabas
yabarnabas
  • 3 Posts
Photo of Nathan
Nathan, Champion
  • 3739 Posts
  • 307 Reply Likes
Hello yabarnabas,
You can't put code right before the closing body tag, but you can put it near it and it will work.
There are two ways to do this, the first one is the best way:
Option 1: Edit your Site's Tracking Code for the "Footer". To do this, go to Site > Site Settings > Site Tracking Code and insert the code into the 'Footer Code' text box. The great part about this is that it applies to every page. You should try this on a test website first to make sure it doesn't break your pages.
Please note: This option is only available to Yola Silver customers. If you have Yola Free, you will have to go with the second option.
Option 2: Drag over an HTML widget from the "Basic" category and then place it at the bottom of the page. This will be as closest at possible to the </body> closing tag.
Please note: You will need to do this to every page you want the in-text adds on.
I hope this helps.
Sanja
Hello yabarnabus,
Please let us know if you still have trouble with this.
Photo of yabarnabas
yabarnabas
  • 3 Posts
Dear Sanja,
still its not working so plz help me.
Photo of yabarnabas
yabarnabas
  • 3 Posts
Dear Sanja,
Sorryyyyyyy sanja its working infolinks ads are displaying on my site,
Thankyou very much for your help sanja.
Photo of Nathan
Nathan, Champion
  • 3739 Posts
  • 307 Reply Likes
You're welcome. :)
Sanja
Hello yabarnabas,
I'm so glad that Nathan's suggestions have helped! Thanks for letting us know!
