Need help adding guestbook?
I want to add a gestbook to my site, can I do that and another is I have tried searching for guestbooks for my website do you have any ideas?
Photo of Heartbeat
Heartbeat
  • 34 Posts
  • excited
Photo of Ruth
Ruth
  • 2819 Posts
  • 135 Reply Likes
Hi Heartbeat,
You can add a guest book to your site. Here's how:
1. Drag and drop a Widgetbox Gallery widget onto your page.
2. A dialogue box will open, search for 'guest book' to see all the widgets available.
3. Choose the widget you would like to use on your site, and customise the settings.
4. Click on the green 'Get Widget' button and it will be saved and added to your page.
5. Save and preview your page to view the widget.
Alternatively, you can add a guest book to your site by adding a specific widget to your site from one of the other widget libraries (like Google Gadgets, Slide.com, Spring widgets etc). Here are the steps using Slide.com as an example.
1. Add a Slide.com widget to your site (you'll find it in the "Widgets" folder at the right of your screen).
2. A dialogue box will open up. Click on the link which will take you to Slide.com (the blue writing in the bottom right hand corner).
3. In the Slide.com website select the "make a guestbook" option.
4. Customize your guestbook and then click "save".
5. Copy the code provided and paste it into the dialogue box back in Yola.
6. Click on "ok" and you will have a guest book for your site
If you don't like any of these options, please visithttp://www.smartgb.com/ or Google for 'free guest book'. Customise the guest book, copy the HTML code provided and paste it into an HTML widget that you've added to your page.
I hope you can find one that you like.
Photo of Heartbeat
Heartbeat
  • 34 Posts
Thank you so much for your help, I will try it. Thanks.
