Need help please
  • Updated 10 years ago
I am creating a wrestling site and I want to do columns on there but I don't know how I would have the columns posted on my site. I need some help please
Photo of noahc
  • 3 Posts
  • confident, excited
Photo of Christo
  • 95 Posts
  • 13 Reply Likes
Official Response
Hi noah
You can create columns using the two column layout widget.
From the widgets tab, drag the two column layout widget onto your page. You will see the outline of two columns drawn on your page.
Now you can drag whichever widgets you want into the two column layout.
If you want to get fancy you can even drag another two column layout into your two column layout!
You can also resize the width of the columns by dragging the middle line of the two column layout either left or right.
Hope that helps!
