Need help please
  • Updated 10 years ago
Hello, 1st of all im a total noobi using the PC but thanks to Synthasite I am doing my 1st website, im using the code Ed linked
(tried to link teh code but its showing a white box sorry.)
to show the side menu I got from Flashvortex.com thank you very much for the code Ed, i know nothing about codes, heres the question is it possible to get a code for the menu on the side to stay on page when i scroll down? instead of going up? If yes please can someone give me the code and in which line I add it please?
Thanking you in advance
Photo of Patrick
Patrick
  • 89 Posts
  • 1 Reply Like
Photo of Monique
  • 6294 Posts
  • 446 Reply Likes
Hi Lycan76
I am sorry that no one has answered your question yet. Have you published your site yet? If so, please post the URL (web address) so that we can take a look at your page and the problem with your menu. If this is something we can help with we will do our best.
Photo of Patrick
Patrick
  • 89 Posts
  • 1 Reply Like
ok here is the site, made it for my close friend, www.ocaseysbulldogs.synthasite.com its my 1st website im still learning !!
Photo of Monique
  • 6294 Posts
  • 446 Reply Likes
Hi Lycan76
Thanks for posting the link to your site! You are doing an amazing job, especially since this is your first website. I don't have the answer to your original question. Maybe Ed can help with that. But once I was able to tear my eyes away from the cute bulldogs I did notice another problem.
The buttons in your menu are taking me to your preview URL's. This is the long URL you see when you preview your page from the SynthaSite site builder. However, only you should have access to this URL - you should not link to your preview URL's anywhere on your site, as this will cause problems with the search engines (they will not be able to index these pages)
The URL you need to use is the page URL once your site is published. You can get this by using your base domain and then putting /filename.php of your page at the end. So for example the URL of your index page (homepage) would be www.ocaseybulldogs.synthasite.com/ind...
Any easy way to get the proper page URL's is:
1) Put all the pages in your menu using the "edit menu" button in SynthaSite.
2) Update your site and go to it.
3) Open each page and copy the URL from your browser window.
You will then have the correct URL's to add to the button code.
I hope this makes sense to you - I am sorry that it is a bit confusing. If you have any problems with this, please let me know.
  • 2582 Posts
  • 279 Reply Likes
Monique good catch with the preview page URL... I never would have thought to look up there. ;)
I am amazed at the overall looks of your site my friend. I think you have done a fantastic job at making it look professional and fun. I would however recommend that you change the images with text contained within them to a text box with the exact text typed then include a pic. As it is the web crawlers don't have any content on your site to read and you know how much they like content. If you wish to keep the images as is then I would maybe summarize the text contained in the images in a separate text widget below each pic.
Just a thought...
Any questions please feel free to ask
Lookin great and keep up the good work...
