Need help putting pay pal buttons on site
  • Updated 10 years ago
I am trying to put 2 buynow pay pal buttons on my yola website. I cant get them to go where I want to put them, and I am trying to put a sentence beside each button with the price. I need some help.
Photo of rob sexton
rob sexton
  • 1 Post
Photo of Peter
Peter
  • 2569 Posts
  • 113 Reply Likes
Hello Rob,
People have used the two sided widget for this purpose with success.
You place a two sided widget on your page and place the button in the Right column of that two column widget.
The two column widget allows you good placement manoeverability from left to right. Vertical placement is a little less precise. You can place blank text widgets above the two column widget to sort of pack it downwards. You can increase the vertical distance then by simply entering blank lines by hitting the carriage returns.
Another unexplored option maybe to have a look at littleus post from last night. She has created an array whereby you can place images . This may suit your need.
http://getsatisfaction.com/yola/topic...
If you have any further questions or would like more specific help, please get back to us here and we'll answer or direct you further.
