Need Help with disclaimer for Free Distribution!
Hey champs and experts! Need help here, on this page www.3rdace.com/downloads.php i am distributing few freebies like menus and web buttons, if you download any file ull see the license, i need to know if its okay or do i need to add few more things to protect my back. Cheers! Thanks.
Photo of sagar
sagar
  • 171 Posts
  • 1 Reply Like
Photo of KanThaiDecor
KanThaiDecor
  • 2402 Posts
  • 263 Reply Likes
If they are your creations you can do as you wish.If they are the work of others you should go back to where you found them and see their conditions concerning use.
Photo of sagar
sagar
  • 171 Posts
  • 1 Reply Like
Yes They are my creations, what i meant was if people download them and then either resell them ur use them for something unethical or illegal, i want to be protected.. if you download a file you will see that i have a license there but want to know if anything could be added to that lisence.
KanThaiDecor
  • 2402 Posts
  • 263 Reply Likes
Here check this site out it should help you on this subject...http://creativecommons.org/
Photo of sagar
sagar
  • 171 Posts
  • 1 Reply Like
that helps! thnx mate!
