need help with ftp
How do I find the FTP server address so I can link some software to my domain website?
Photo of sudgirl
sudgirl
  • 2 Posts
Photo of Ruth
Ruth
  • 2819 Posts
  • 135 Reply Likes
Hi sudgirl,
SynthaSite does not use FTP. Can you tell me a little more about what you are trying to achieve and I can make some suggestions.
Photo of Christine
Christine
  • 5 Posts
the product is asking me for ftp:// Host
Photo of Emmy
Emmy
  • 5892 Posts
  • 299 Reply Likes
Hello Christine,
Yola does not have ftp capabilities, can you tell us more about what you are trying to do with the profile management program you have, possibly we have another suggestion.
Photo of Christine
Christine
  • 5 Posts
Profile Manager does all the work when users log in to create a profile, add images, update profile, and or delete their profile
Photo of Emmy
Emmy
  • 5892 Posts
  • 299 Reply Likes
I would need to know more about what type of files you need to run this on your site. If it requires uploading file types such as .php or .html into the site builder than it would not be possible. If you can give us more specific details we can give you a definite answer on if it is possible or not.
Photo of Christine
Christine
  • 5 Posts
Thanks for your help, i will go with what another person did and embed a link
Photo of sudgirl
sudgirl
  • 2 Posts
I am trying to install an affiliate marketing program for my domain website.
Photo of Christine
Christine
  • 5 Posts
I am trying to install Profile manager
Photo of rainbowvalley
rainbowvalley
  • 4 Posts
  • 1 Reply Like
i am trying to download google friend search nd my website wont let me download 2 files that i need 2 download. help?
rainbowvalley.co.nr
Photo of Peter
Peter
  • 2569 Posts
  • 113 Reply Likes
Hello Rainbowvalley,
The goodnews is that you don't have to download those two files. They have already been downloaded by Yola to their servers.
Here's the link to the installation of GFC on Yola sites.
http://getsatisfaction.com/SynthaSite...
Please read this completely before installing GDC, it helps!
At the end of the installation you will be notified of what looks like an error. it isn't. If you then save and publish, check your GFC you will see that you have successfully installed it.
Great luck.
Photo of Ruth
Ruth
  • 2819 Posts
  • 135 Reply Likes
Thanks Peter.
rainbowvalley
  • 4 Posts
  • 1 Reply Like
It is still not working i keep trying but it says that the 2 files cant be detected. this is all very confusing. help!
rainbowvalley.co.nr
Photo of Peter
Peter
  • 2569 Posts
  • 113 Reply Likes
I see you have the GFC wall board working.
For installing your GFC were you working on your alias "rainbow.co.nr" or your original synthasite account?
