Need help with sound mouse over
  • Updated 10 years ago
trying to get sound mouse over to work. Having no luck. Any suggestions?
testpager.yolasite.com/
Photo of Harry
Harry
  • 82 Posts
  • confused
Sanja
It looks like you may not put your code in properly as part of the code is showing up on your site.
also.. you didn't put in your full path to your audio clip.
If you can post your code here, then we can help you out. Be sure to encode your code first. Go here: http://forsite.synthasite.com/encoder...
Photo of Harry
Harry
  • 82 Posts
<script LANGUAGE="JavaScript"> <!-- // Preload and play audio files with event handler (MouseOver sound) // designed by JavaScript Archive, (c)1999 // Get more free javascripts at http://jsarchive.8m.com var aySound = new Array(); // Below: source for sound files to be preloaded aySound[0] = "http://testpager.yolasite.com/resourc... Shot.wav "; // DO NOT edit below this line document.write('<BGSOUND ID="auIEContainer">') IE = (navigator.appVersion.indexOf("MSIE")!=-1 && document.all)? 1:0; NS = (navigator.appName=="Netscape" && navigator.plugins["LiveAudio"])? 1:0; ver4 = IE||NS? 1:0; onload=auPreload; function auPreload() { if (!ver4) return; if (NS) auEmb = new Layer(0,window); else { Str = "<DIV ID='auEmb' STYLE='position:absolute;'></DIV>"; document.body.insertAdjacentHTML("BeforeEnd",Str); } var Str = ''; for (i=0;i<aySound.length;i++) Str += "<EMBED SRC='"+aySound[i]+"' AUTOSTART='FALSE' HIDDEN='TRUE'>" if (IE) auEmb.innerHTML = Str; else { auEmb.document.open(); auEmb.document.write(Str); auEmb.document.close(); } auCon = IE? document.all.auIEContainer:auEmb; auCon.control = auCtrl; } function auCtrl(whSound,play) { if (IE) this.src = play? aySound[whSound]:''; else eval("this.document.embeds[whSound]." + (play? "play()":"stop()")) } function playSound(whSound) { if (window.auCon) auCon.control(whSound,true); } function stopSound(whSound) { if (window.auCon) auCon.control(whSound,false); } </script> <!-- //onMouseOver/onMouseOut sound: --> <a href="http://testpager.yolasite.com/resourc...; onMouseOver="playSound(0)" onMouseOut="stopSound(0)">Move mouse over to play sound</A> <!--//Edit the aySound array to preload the sound files. //aySound[0]="resources/Gun Shot.wav"; //aySound[1]="AnotherSoundFile.wav"; //aySound[2]="EvenAnotherOne.wav"; -->
Sanja
Hi Harry
Just wanted you to know that I haven't forgot about you. It's been a very busy day today and I haven't had a chance to sit down at the computer and look at this in more detail. I'm hoping to get to it tomorrow.
Sanja
Hi Harry.. I'm taking a look now at your code.
Can you please give me the location of where your audio files are held? Thanks.
Sanja
yep.. that's what I'm looking for! Thanks. I'll get back to you. Thanks for being so patient with this.
Sanja
also.. could you please provide the url where you got your code please. I always like working from the original source in case there was a mistake in copying the code.
Photo of Harry
Harry
  • 82 Posts
Sanja
Thanks for that source... but what I meant was.. where did you get your script code from?
Sanja
It's okay Harry.. I found the source. I think the problem is this... on the site, it says the following: "the LiveAudio plugin must exist" in order for the sound to come through. This only seems to work with IE or NS - not Firefox.
Sanja
Here's the code again.. I was able to make it work for me. Also.. looking at your audio file - it looks strange - I don't believe it should have two .wav in it.
Step 1: Copy & paste into an HTML box
<script LANGUAGE="JavaScript"><!--
aySound[0] = "resources/gunshot sound fx 98010.WAV";
ver4 = IE||NS? 1:0;
onload=auPreload;
if (!ver4) return;
else {
var Str = '';
else {
</script>
Step 2: Copy and paste into another HTML box
<A HREF="http://testpager.yolasite.com&quot; onMouseOver="playSound(0)" onMouseOut="stopSound(0)">Move mouse over to play sound</A>
Also... try downloading your audio file again.
Let me know if you need further help. In the meantime, I'll scrounge around and see if I can come up with an audio player that will work on all browsers.
Sanja
Hi Harry
I found one that appears to play in both FF and IE.
<script type="text/javascript">
if (window.attachEvent)
window.attachEvent("onload", setupPlaySound);
else
window.addEventListener("load", setupPlaySound, false);
function setupPlaySound()
if (navigator.appName == "Microsoft Internet Explorer")
var snd = document.createElement("bgsound");
document.getElementsByTagName("body")[0].appendChild(snd);
playSound = function(url)
snd.src = url;
else
var obj = document.createElement("object");
obj.width="0px";
obj.height="0px";
obj.type = "audio/x-wav";
obj.data = url;
var body = document.getElementsByTagName("body")[0];
body.appendChild(obj);
</script>
Step 2: Copy & paste into another HTML box. This is where you put in your audio file path.
<a href="SomePage.htm" onmouseover="playSound('resources/gunshot sound fx 98010.WAV')">Click Here!</a>
I hope this one does the trick for you. =)
If you want to see the testpage I created: http://littleustestsite.yolasite.com/...
Photo of Harry
Harry
  • 82 Posts
FF
Sanja
Okay... so am I. It's very strange.
If you can persevere, I'm sure we can get this figured out.
I'm going to post the code again. Maybe I missed something? Your sound file should be in your resources folder right? It not in another folder as well as the resources folder?
Photo of Harry
Harry
  • 82 Posts
Ok here goes. There is a file on my hard drive and one in resource folder. When i right click on the one in the res folder, i have to download it. the one in the res folder is the double .wav
Photo of Harry
Harry
  • 82 Posts
if i right click on the res folder file, i have the option of-copy,rename,download and delete
Sanja
yep.. that 's right.. so click on rename and give it a new name.
Sanja
Harry.. check out my test site page.. is that what you're wanting to accomplish?
Sanja
I think you're missing an " after your image file name. Try inserting that between .JPG and border="0"
Sanja
Okay.. try naming the audio file in your resources folder. It should read: gunshot sound fx 98010.WAV
Let me know when you've got that done.
Sanja
It sounds good to me! I don't hear anything being cut off at all. Maybe you could repost your testpage in a new thread and see if others are experiencing the problem you're having when they visit it?
Photo of Harry
Harry
  • 82 Posts
That worked but the sounds are different between your site and mine because there are two different gun shot sounds. I changed sounds. see iy it works for you. http://testpager.yolasite.com/
Sanja
Yep.. it worked! =) Yay!!!!
Photo of Harry
Harry
  • 82 Posts
Thanks again. i don't know where you live but in your are ever in the philly area, you know how to get me, i'll buy your a beer.
Sanja
You're very welcome! I'm so glad we got it to work. Thank you for being patient and not giving up! =)
As always, feel free to ask question if the need should arise.
