Need help with the new Sub menus and removal of top banner!!
I am using the Grunge Splatter template for one of my sites: www.theblackboxtheatre.org. Is there a way for me to get rid of just the top banner bar so that I can add a photo slide show in that spot? Also can someone help me with the new sub-menu option. I can't seem to figure out how to work it. Is this function just for the Yola Silver or will it also apply to any premium site that was purchased individually?
Photo of Dnett
Dnett
  • 23 Posts
  • 1 Reply Like
  • wishful.
Photo of diane
diane
  • 1238 Posts
  • 121 Reply Likes
Hi, Dnett,
One suggestion is to use the margins to place a slide show in that area. Click on Margin in the upper left corner of the widget where you have the slide show and put in a negative top margin. This will move the widget up. Be careful not to put too high of a number--you will need to experiment. (If you place your widget with the slideshow in a Column Divider Widget, this will give you a way to delete the widget if it disappears from your page.)
We have a video tutorial on submenus here: https://www.youtube.com/watch?v=vcCqD3... This is just for Yola Silver.
