Need help with Wufoo
I created a contact form with Wufoo. Now why is it that I cant
edit this text box? When I try to click into it to edit, I'm taken
to the Wufoo site where I'm asked to paste the code.
Secondly, I created my own navigation bar using links. The links (Home,
About, Services, Blog ) look like size 12 font, whereas the Contact
(from Wufoo) appears to be size 8 or 10.
Photo of jin
jin
  • 6 Posts
  • confused
Sanja, Official Rep
Hello Jin
Since you made the form on Wufoo - you need to also make your edits at Wufoo. Then, save your edits, and copy the code and re-paste into your Sitebuilder.
Can you please share your URL so that I can take a look at your Navigation bar? Thanks.
Photo of KanThaiDecor
KanThaiDecor
  • 2402 Posts
  • 263 Reply Likes
They have improved editing.....Edits made at Wufoo auto update on your site.
Sanja, Official Rep
w00t! That's great news!
Photo of Donald
Donald
  • 2991 Posts
  • 37 Reply Likes
it's been a while since I've used wufoo, but it's probably dynamically or javascript created... therefore, although you may see portions of the design in the code in yola, editing it, may possibly make the whole form disappear. Doing it in wufoo is easy from what I remember, look for the option for "form design".
Also, the wufoo paste your code page you're speaking of, that is where you will see your code and if editing is allowed, that's where you would do it.
Photo of jin
jin
  • 6 Posts
Hi, you can see from my custom navigation bar on the left that I can edit
everything except 'Contact'. Contact is in a separate text box from the other menu items
and I cant click in it to edit. http://dellasspa.yolasite.com/
Photo of jin
jin
  • 6 Posts
Just to be clear, it's not the Wufoo form that I want edited, it's the word "Contact" in
my navigation bar to the left of my screen. I want all 5 items to be the same font size.
Sanja, Official Rep
Hello Jin
I took a look at your issue. You will need to add a font size to your contact form. Please edit your code in your Wufoo form to look something like this:
<!--<a href="http://daisy7.wufoo.com/forms/m7x3k1/" title="Contact"><font size="10">Contact</font></a>-->
You can change the font size from 1-10.
Please don't include the <!-- and -->. They are simply there to stop the forum from intepreting the code.
Please let me know if you have any further trouble with this.
KanThaiDecor
  • 2402 Posts
  • 263 Reply Likes
Good to see you here more often my Champ sister....Were you away getting a windows 7 upgrade for your A.I. program?
Sanja, Official Rep
Ha! My A.I. program still has lotsa life left. No need for Windows 7 :D
Photo of Donald
Donald
  • 2991 Posts
  • 37 Reply Likes
Hello Jin,
Just wondering, is there a reason you're using two widgets for the same menu? It appears your contact is in a seperate td element. If you change it up to the same widget, it'll make editing much simpler. I'm also noticing that your html code for Contact is....
<a href="http://daisy7.wufoo.com/forms/m7x3k1/" title="Contact">Contact</a>
and for the rest is...
<p style="color: rgb(0, 136, 204);"><font size="4">Home</font></p>
If you change the html of "Contact" to be identical to the second code above, then it'll be the same format as the rest of the menu items.
Photo of jin
jin
  • 6 Posts
This code worked <!--<a href="http://daisy7.wufoo.com/forms/m7x3k1/" title="Contact"><font size="10">Contact</font></a>--> Now how do I change to color to blue?
Regarding Donald's question about using 2 widgets - I couldn't get the Wufoo form
into the top widget, it just wouldn't go in there so I created separate one. I'm not too good at this stuff so I just have to make do. Sigh.
Sanja, Official Rep
Hi Jin
I just had a thought! You could use the embed code rather than a link to your contact form! Then, you can add the "Contact" link the same way that you have for your other existing menu links.
On your contact page, add your Wufoo widget. This time, instead of copying the link code, copy the embed code.
Please let me know if you have any trouble with this.
Photo of jin
jin
  • 6 Posts
Sanja, this was a great idea. Unfortunately it didn't work. I tried it several times but kept
getting "this link appears to be broken".
Photo of jin
jin
  • 6 Posts
Sanja's astute way of thinking is rubbing off on me. I read in another thread where she mentioned Jotform. So I decided to try Jotform (instead of Wufoo) using her idea above and Voila, it worked! I have my contact form and link exactly the way I want it. Thank you Sanja for the suggestion!
Sanja, Official Rep
Hello Jin
My apologies for the late reply. The comment you had left did not show up on here until now.
I'm so pleased to hear that you were able to find a solution that worked for you!
