Need your help with some code for rollover images
  • Updated 7 years ago
Hi there...
I'm using the code below to add some rollover images to my site... it works well but it stucks the images to each other...
How can I modify the code to have some blank space between the images?
The code is:
Thank you!
Photo of Dimitar Kunev
Dimitar Kunev
  • 4 Posts
  • sad
Posted 7 years ago
Photo of Gop
Gop
  • 7473 Posts
  • 2115 Reply Likes
Hello Dimitar,
can you wrap your code in the tags < code > code here < /code >. This will allow the code text to be seen. (Take out the spaces after the < and before the >, which is required for the explanation here only).
Dimitar Kunev
  • 4 Posts
<SCRIPT LANGUAGE="JavaScript">
<!-- Begin
loadImage1 = new Image();
loadImage1.src = "http://sitename.com/resources/11.jpg";
staticImage1 = new Image();
staticImage1.src = "http://sitename.com/resources/1.jpg";
loadImage2 = new Image();
loadImage2.src = "http://sitename.com/resources/22.jpg";
staticImage2 = new Image();
staticImage2.src = "http://sitename.com/resources/2.jpg";
loadImage3 = new Image();
loadImage3.src = "http://sitename.com/resources/33.jpg";
staticImage3 = new Image();
staticImage3.src = "http://sitename.com/resources/3.jpg";
loadImage4 = new Image();
loadImage4.src = "http://sitename.com/resources/44.jpg";
staticImage4 = new Image();
staticImage4.src = "http://sitename.com/resources/4.jpg";
loadImage5 = new Image();
loadImage5.src = "http://sitename.com/resources/55.jpg";
staticImage5 = new Image();
staticImage5.src = "http://sitename.com/resources/5.jpg";
// End -->
</script>
<span onmouseover="image1.src=loadImage1.src;" onmouseout="image1.src=staticImage1.src;">
<img name="image1" src="http://sitename.com/resources/1.jpg" border=0></span>
<span onmouseover="image2.src=loadImage2.src;" onmouseout="image2.src=staticImage2.src;">
<img name="image2" src="http://sitename.com/resources/2.jpg" border=0></span>
<span onmouseover="image3.src=loadImage3.src;" onmouseout="image3.src=staticImage3.src;">
<img name="image3" src="http://sitename.com/resources/3.jpg" border=0></span>
<span onmouseover="image4.src=loadImage4.src;" onmouseout="image4.src=staticImage4.src;">
<img name="image4" src="http://sitename.com/resources/4.jpg" border=0></span>
<span onmouseover="image5.src=loadImage5.src;" onmouseout="image5.src=staticImage5.src;">
<img name="image5" src="http://sitename.com/resources/5.jpg" border=0></span>
Photo of Gop
Gop
  • 7473 Posts
  • 2115 Reply Likes
Hi Dimitar,
You can add a </br> to the HTML in the lower segment of the code after each < /span >. This will add one line spacing between each image. You can add more if you wish more space.
Dimitar Kunev
  • 4 Posts
Hi there...
For some reason adding <br> or </br> tags doesn't do the job... They stay stuck together!
Please help!
Photo of Gop
Gop
  • 7473 Posts
  • 2115 Reply Likes
Hello Dimitar,
I will re-create this on a test site and get back to you within 24 hours if that's OK?
Gop.
Photo of Gop
Gop
  • 7473 Posts
  • 2115 Reply Likes
Hi Dimitar,
This code doesn't produce any outcome for me on my test site. I'll wait to hear from you if there is additional code.
Dimitar Kunev
  • 4 Posts
Hi there...
I made it work using <p> and </p> tags...
Thanks for the help!
