One solution for site builder loading problem
  • Idea
  • Not Planned
Just an FYI. I was having trouble getting site builder to load. Also had "dropinsavings" popup toolbar coming up. Found a suggestion on line to disable the "dropinsavings" toolbar by disabling the extension called FaceTheme (in Fire Fox under Tools | Add-Ons | Extensions). This got rid of the dropinsavings tool bar and solved my site builder loading issue as well
Photo of lkottke
lkottke
  • 2 Posts
  • happy
Photo of Justine
Justine
  • 751 Posts
  • 45 Reply Likes
Thanks for the helpful suggestion, lkottke! I'm sure many Yola users will find this really useful.
Photo of Twiglet
Twiglet
  • 2 Posts
What do you do if you aren't using Firefox?
I'm with Google Chrome, don't have any tool bar installed, and the bloody thing is popping up all over the place.
Why is every solution from Firefox?
Photo of Twiglet
Twiglet
  • 2 Posts
I've noticed that I have or at least there are 9 Dropin Savings on this very site. I don't know if anyone else is experiencing this right now...
It began on one website, and now seems to be spreading - I hope I'm not doing anything to cause this. I can't think of anything different that I've started doing over the last month or so. In spite of their being annoying, I imagine they'd be fairly useless to me - I'm finding them mostly on U.S. websites, however I'm actually from Australia. They'd probably have no value here, although I wouldn't trust them wherever I was from.
Sanja
Hello Twiglet,
This is a toolbar that you can most likely disable on your Google Chrome. Here's a link with more information which I hope will be of help to you: http://www.google.com/support/forum/p...
