PHP T Html converting problems evansfunfair.com help asap
I would like to move my domain name to evansfunfair.gotdns.com wich i on my own pc at home but whn i download the site it will not work just comes up witha load of garble jumbled up rubbish is there a way that yola can convert the site to html so that i can accsess the page from my home pc in html format as i have my own domain at home i wish to use insted of yola thank you evansfunfai.com
Photo of funfairevans
funfairevans
  • 21 Posts
  • 1 Reply Like
  • frustrated
funfairevans
  • 21 Posts
  • 1 Reply Like
please help
Photo of Emmy
Emmy
  • 5892 Posts
  • 299 Reply Likes
Hello funfairevans,
When you download your site it will be in zipped format and you can save it on a CD. However, in order to view the content of your site it needs to be uploaded to a PHP enabled server through another hosting provider.
Please note that once you download your site, you are not able to upload back into Yola's site builder. If you were wanting to view your site through Yola, then you will need to use Yola's site building tools to do so.
I am not sure whether these instructions will allow you to achieve what you had in mind. However, this is the way our site builder works. Please let me know if you have any further questions.
Kind Regards,
Emmy
funfairevans
  • 21 Posts
  • 1 Reply Like
yes you didnt answer my question with my home domain name can i use my site on it or could yola convert it to html or have you any nolage or any free programs to convert it to html
Photo of Emmy
Emmy
  • 5892 Posts
  • 299 Reply Likes
Hello,
Unfortunately I am not aware of a way that you can change the code of your site so that it could be used on your desktop.
You can surely use a domain purchased from Yola elsewhere if you would like, you would just need to edit the records (either A Records or Name Server Records) to point towards the hosts ip address. If this is something you would like to do please see our tutorial: Managing your domain bought from Yola.
Please let us know if you have further questions.
Emmy
