Please help me. Im going insane. Synthasite/Zoneedit.com... Nothing helping
  • Updated 10 years ago
I went onto synthasite.com. Made a website, went to publish, it asked if i ouwld like to purchase a domain, i did. then it took me thorught the toutrial and everything so i went onto zoneedit.com and and regiestered with them, then they said i needed to go to my registar purchaser domain person whom i got my domain from and tell them to change my nameserver. I HAVE NO IDEA HOW TO DO THIS i have read through all the guys typed in all the key words and pretty sure i have wasted the past three hours of my life. please help
Photo of tantalizinggsun
tantalizinggsun
  • 1 Post
  • FRUSTRATED!!!!!!!!!!!!
Photo of Marije
Marije, Official Rep
  • 4636 Posts
  • 237 Reply Likes
Hi tatalizinggsun,
Did you buy the domain from SynthaSite or from another domain registrar? If you bought the domain from us, you won't need to use ZoneEdit's services. Your site will be published to your bought domain.
If you bought a domain from another domain registrar (like godaddy.com, register.com etc), you can edit your DNS settings (add an A Record) so that your domain works with SynthaSite.
If the domain registrar doesn't offer the ability to add an A Record, then you would need to use ZoneEdit.
Can you confirm which one you're using and if it's another registrar, can you let us know which one?
