Please help! Store front/department issue!
  • Updated 7 years ago
  • In Progress
Hi
I wanted to make some changes to my site but have now found that two of my pages aren't working in the way they were before (all I did was change the margins after adding a text box.) Before this the pages showed "store>name of department", now two of the pages show "store", then I have to click on ne of the pictures on the store front to gain access to the department. Any ideas?
A
Photo of A
A
  • 87 Posts
  • 1 Reply Like
Posted 7 years ago
Photo of Stefan
Stefan
  • 4448 Posts
  • 190 Reply Likes
Hello A
Are you talking about your website http://www.gemipreciousjewellery.co.uk/? I'm afraid it hasn't become quite clear to me what you mean and try to achieve. Which pages do you mean, can you give us the names? I don't see the "Store" link on your home page, only when I click on the pictures of your home page. Can you please give us a little more details of what you would like to do?
Photo of A
A
  • 87 Posts
  • 1 Reply Like
Yes it is the site.
The live site works OK as I haven't yet updated any of the changes I am trying out. The issue is occurring in the off-line site set up pages when I preview my changes. As I said above the issue happened after I added a text box and changed the margins. Prior to the change I made (on the off-line set up pages) on preview the pages looked exactly as they do on the current live site, but after the changes when clicking on 'Bracelets' I get taken to the store front page!
The links at the top of the page now go only to the store (>store) which takes me to the store front rather than (store>bracelets) which takes me to directly to the products page
Below pictures might help understand what the issue is.
As on live site
After change
Off to the dentist now :-(
Many thanks
A
Photo of Stefan
Stefan
  • 4448 Posts
  • 190 Reply Likes
Hello A
For some reason the product category display must have been changed to default after you had edited the margin. You can get the right category display back quite easily:
  1. Go to your "bracelets" page in your Yola Sitebuilder.
  2. Click on "Edit" on your Yola Online Store Widget.
  3. Choose "bracelets" from the drop down menu under "Categories to show".
  4. Click on "Save".
You should now see the right category bread crumb navigation, and your edited margin should apply as well. I hope this issue will not go on causing you toothache. ;-)
Photo of A
A
  • 87 Posts
  • 1 Reply Like
Brilliant Stefan, thank you. That was the only thing I didn't think of doing!! No the toothache wasn't caused by this, just a cracked tooth, all fixed now.
Thanks for your help
A
