Please view my site,also I.E. browser problem
Hello all.
Can someone please view my site and tell me what you think so far,just needs a few touches
.Also in I.E. browser,menu looks fine,the rest of the page is way down.
I build this site in firefox and its looks fine
http://ramadan-daily.yolasite.com/
Thank you.
Photo of ramadan-daily
ramadan-daily
  • 8 Posts
Photo of Yola_User_A
Yola_User_A
  • 276 Posts
  • 3 Reply Likes
Hi, looks great to me... Are you using html tables or have you used the Yola three column layout???
If you have designed your own tables using html, in the table attribute you might need to add or change your td or table attributes so that your content in the table will start at the top...
If you leave the valign and align properties out of your tables your content may appear way over or way down...
add --> align="center"
and
-- > valign="top"
to your table &/or td attributes
ramadan-daily
  • 8 Posts
Hello again,thanks for answering so quickly.
No i didnt change any html tables,i'm on the yola 2 column left and using the BareNecessities PaleTexture.
I not sure what i should do?Maybe change my column?
ramadan-daily
  • 8 Posts
ok.so my others pages are fine in I.E.,so its just the homepage.I took my widgets off,but that didnt help,i moved everything from my left column to the center and bingo.
It looks like i was taking to much space to the right.
Ive made a big mess now but i will sort it out hopefully.
Thanks very much for your help 'A'
Yola_User_A
  • 276 Posts
  • 3 Reply Likes
Hello again, your site looks amazing! Love the new theme/layout, it really looks awesome! Did you get your problem fixed though?
ramadan-daily
  • 8 Posts
Ohh thanks for the comment,thats made my day
Well silly me was using the BareNecessities PaleTexture,with the width of 3 columns and a menu.So i would think thats what the problem was.Also after shuffling around things,i thought i would go for a new Yola layout.The header i found it on the net.Im not sure about that thought,
Anyway thank you so much,for your help
Yola_User_A
  • 276 Posts
  • 3 Reply Likes
Yeah I think that might have been it, love the final outcome though, I think your website is stellar!
No, problem... You're welcome!
