plz help me adding image to top right corner
  • Updated 10 years ago
i m using a domaim from synthasite ...plzz tell me how to add images at the top right corner of the web layout
Photo of apj123
apj123
  • 1 Post
  • sad
Photo of Kershnee
Kershnee
  • 2087 Posts
  • 152 Reply Likes
Hi APJ123,
Quite a few of our templates have a customizable banner, if the banner image can be changed, you will see a white box with an instruction placed over the default banner image.
To change the banner image:
1) Click on the white instruction box that says "click here to change banner image"
2) The file manager will open up that will allow you to browse your computer for a picture to upload.
3) When you are done, click "ok" and your own image will replace the default image
4) If the dimensions are not quite right you can fix this by choosing the "edit with Picnik" option in the file manager. Picnik is a web-based image manipulation tool that has an option for you to resize your image. When you are done, click "save to SynthaSite" and the new image will replace the old one.
Please note that the white instruction box will only appear in editing mode, and will disappear when you preview or publish your site. Also, you may use the default banner image if you wish.
Regards,
Kershnee
