  • Updated 10 years ago
  • Solved
hey monique my previous problem was resolved I tried linking my page a couple times but it didnt work than when I tried it alot it started to work and then as I logged off and then later logged in again. Clicked on my website to open it and this message poped up saying "Invalid component ( some number) and something, then when i pressed okay the same message poped up again quickly saying the same thing but with a different number and kept going like this untill i clicked it like 10 or 15 times and when it disapear there was nothing on my website expect the pages. What should I do I really worked hard on this website. So please do something. I also reported this on the " report bug " as you said I marked it as " Attention: Monique " Do you have any idea when this problem might be solved. ( Now if you go to my website all you could see is blank pages Im wondering If you do resolve this problem well my pages be back to normal or not because I really spended alot of time working on this website )
Photo of Kumby
  • 211 Posts
  • 4 Reply Likes
  • really realy and extremly FRUSTRATED
Photo of Marije
Marije, Official Rep
  • 4636 Posts
  • 237 Reply Likes
Thanks Deathnote - your email has been received and we'll answer you soon!
Photo of K9Clothing
  • 94 Posts
  • 2 Reply Likes
That happened to me a once. Just sit back, relax and it will fix itself. Trying other browsers doesnt work. I have no idea what causes it however I am thinking it happens when you have a banner in place but then switch to a bannerless layout. At least, thats what happened to me. I thought I lost everything but luckily it did fix itself.
I highly doubt you lost everything :)
Photo of clouda9
  • 323 Posts
  • 3 Reply Likes
Please consider: "Inner silence promotes clarity of mind; It make us value the inner world; It trains us to go inside to the source of peace and inspiration when we are faced with problems and challenges." Deepak Chopra
Photo of K9Clothing
  • 94 Posts
  • 2 Reply Likes
Wise words :)
