PLZ I really need help badly
  • Updated 12 years ago
  • Solved
I signed up for google apps so i can have my own email adress, but it asks me to vertify my website and i tried many times but couldnt get it right. There were two methods of verification.
1st-Create a HTML verification file named googlehostedservice.html , copy the text specified below into it, and upload it to http://animestarr.co.nr/ .
googleffffffffdfda7ece
Once you have made the changes, make sure you can see the file at http://animestarr.co.nr/googlehosteds...
2nd- Sign in to your domain hosting service and locate the DNS management page. The location varies by service, but can typically be found under Domain Management or Advanced Settings .
Use the following unique string to create a new CNAME record for the animestarr.co.nr domain:
Point the CNAME record to:
google.com
Once you have made the changes, you can verify that the record exists by doing a CNAME lookup for http://googleffffffffdfda7ece.animest... . You can find several web sites to do automated CNAME lookups by searching for CNAME lookup at http://www.google.com .
So PLEASE if anyone can help me to vertify my website that will be great, because i really want it to be vertified.
Photo of Kumby
Kumby
  • 211 Posts
  • 4 Reply Likes
  • confused
Posted 12 years ago
Photo of support
support
  • 3 Posts
Hi Deathnote,
Thanks for your post - I will look into it and come back to you when I have an answer!
Regards,
Marije
Photo of jason
jason
  • 13 Posts
  • 5 Reply Likes
Hi
Unfortunately it looks like verification is not possible using the upload html method or cname (on .co.nr)
1. Html: upload: You can't create a page called googlehostedservice.html page on synthasite. Creating a new page called googlehostedservice will create a page called googlehostedservice.php
2. Cname: I read up on .co.nr and they dont seem to offer cname records at all which means the 2nd option is not available to you.
http://www.forums.co.nr/index.php?sho...
