Pointing Problem
  • Updated 6 years ago
I went to the juice session yesterday and was told that my site was pointed correctly.
I still cannot publish my site.
Photo of Daniel South
Daniel South
  • 7 Posts
Posted 6 years ago
Photo of Jackie
  • 640 Posts
  • 35 Reply Likes
Hi Daniel,
I have checked your A records for southlaw.co.uk and they are still not pointed. It can take up to 48 hours for the change to propagate across the internet, so depending on when you changed them, it could be that they are still propagating.
You can check your A records for yourself by using a third party DNS look-up: http://www.kloth.net/services/dig.php
If you enter "southlaw.co.uk" into the Domain field, and click "Look it up", you will see that the A record is blank. If you do the same for "www.southlaw.co.uk" you will get the same result.
I hope this helps. I would suggest contacting your registrar to see if they can provide you with any more information.
