problem with font with style designer
  • Updated 5 years ago
I am a very happy customer with yola since 2009. I made few website with yola and I always managed to changed font of the writing very easily.
Since there is the new system Style designer I don't manage to change the font of some widget.
If I change the style with Style Designer it changes the font of the WHOLE website and all my pages headers change font.
How do you individually change the font and style for section of text with a page?
thank you
here is an example of a page of my website
http://sitebuilder.yola.com/ide/index.jsp?siteid=8a4986cb20d5fcc50120deb074fd77f0
Photo of fiamma
fiamma
  • 41 Posts
  • 4 Reply Likes
Posted 5 years ago
Photo of Gop
Gop
  • 7473 Posts
  • 2115 Reply Likes
Hello fiamma,
If you can tell us the address of your published site rather than the sitebuilder, then others can look for you.
Photo of fiamma
fiamma
  • 41 Posts
  • 4 Reply Likes
Photo of Gop
Gop
  • 7473 Posts
  • 2115 Reply Likes
Hello fiamma,
The style you have chosen is Squeaky Clean with Black background.
This style does allow for individual font selections of: Navigation, Main Header, Paragraph, Link etc. using the Style Designer.
If you change for example your navigation font to a specific font type and also change your Main Header to another font, it will successfully perform that. What it does do though is change these fonts on all pages of your site. So you can't use the Style Designer to change your Main Header to Font type ABeeZee with a certain weight etc and then set another page Main Header to another font type. It just can't do that. It's designed to be effective for the whole site and not individual page variations. It's the design philosophy of the Yola model.
You can change these by using Inline CSS but it is rather complex and tedious
Photo of fiamma
fiamma
  • 41 Posts
  • 4 Reply Likes
thanks but your answer isn't very comforting.
I have this website for 5 years and I never had a problem adding a new page.
I need to add pages on a regular base to add new projects. Actually I used to change the coding in CSS also so I am not scared to do it again if needed.
There is no way I change the font on all pages. I actually can't find how to access the CSS anymore. there used to be an easy way to get to it.
please help me, I am very sad not to be able to update my website any more the way I used to
Photo of Gop
Gop
  • 7473 Posts
  • 2115 Reply Likes
Hello fiamma,
If you used to do it previously then you still can do it. You must ensure, however, that the Style Designer is turned off otherwise the two systems compete with each other.
To access CSS, navigate through: Style → Settings  → Site CSS
To add an additional page:
Page  ↓
and you will see the green + sign
