Problem - can't point to my Yola Bronze website using a 3rd party domain name.
  • Solved
Yola's description of the features of the Bronze package as well as the Silver includes the ability to point to an external Domain.
I've recently built a 'free' Yola site and published it using the Yola subdomain name, and then upgraded to your Bronze package so that I can point to it from an external Domain I had previously bought. I've followed the requirements at my Domain site to point to Yola and received confirmation from Yola that my Domain name is pointed at Yola. However, when I tried several times to enter my Domain name in the Yola section for using a domain name from an outside party all I get is the comment : Your domain is not pointed at Yola.
Please advise why I'm getting these contradictory messages from Yola which is preventing publishing my site.
Photo of Peter
Peter
  • 3 Posts
Photo of Jackie
Jackie
  • 640 Posts
  • 35 Reply Likes
Hi Peter,
Could you provide me with the name of the domain that you are trying to point to Yola, and I will look into this for you.
Thanks!
Photo of Peter
Peter
  • 3 Posts
Hi Jackie,
Thanks for your quick response.
My Yola site is : http://www.sdba.yolasite.com/
My 3rd party Domain name is : sdba.org.uk
Attached are screenshots of the 2 conflicting messages I'm seeing from Yola.
Much appreciate your help.
Regards,
Peter
Photo of jeremy
jeremy
  • 1349 Posts
  • 90 Reply Likes
Hello Peter,
I am sorry you are having this problem.
It seems you have 2 different A records on your domain.
One is pointing correctly to 184.72.229.176 and the other (your non-www domain) is pointing to 213.171.195.105
sdba.org.uk. 3600 IN A 213.171.195.105
Can you please make sure both ate pointing to Yola's IP and then you will be able to publish your site to your domain.
I hope this helps.
Photo of Gus H
Gus H
  • 1 Post
Dear operator, I want to point my fasthosts domain name (www.hiddenmeanings.co.uk) to my yola address. Please give me an idiots guide on how to do this as I'm a pure beginner. Your explanation says I need to create 2 'A' records, but I don't know what these are. Your help is much appreciated. G H
Photo of Gop
Gop
  • 7473 Posts
  • 2115 Reply Likes
Hello Gus,
Your best advice on this is to contact Fasthost and ask them their procedure in pointing your domain to Yola's servers.
As mentioned it's important to have 2 A records set up, both pointed to he IP address: 184.72.229.176. One is for the non-www. version and one for the www. version of your domain. All this is done on Fasthost's side and not on Yola's side.
You do need a hosting plan with Yola to be able to accept the pointed domain as well. It won't work without a hosting plan. This is most economically done by buying a subscription to Yola Bronze. (you may upgrade subsequently if you need to and this can be done easily and quickly)
