Problem in logging in Yola ..........
  • Updated 10 years ago
I m not able to log on to my Yola (synthasite) account . I am sure that my username and password is correct but i am not able to log in . The page shows Login Failed . Now what to do ? Are any of u experiencing same problems .......
Photo of Prateek
Prateek
  • 3 Posts
Photo of Shaq
Shaq
  • 868 Posts
  • 5 Reply Likes
I am not experiencing any problems.
I recommend you email
support@yola.com from the email you signed up with. They can help you from there..
Photo of Kershnee
Kershnee
  • 2087 Posts
  • 152 Reply Likes
Hi Prateek,
I'm sorry you are having this problem. I just tested this on my side and was able to login. This normal happens when the username or password is incorrect. I would suggest resetting your password.
You can reset your password as follows:
1. Click on the "forgot password" link below the login boxes in the top right hand corner of the Yola homepage or click on this [link](http://www.yola.com/user/forgotpass)
2. Fill in the email you used to create your account
3. Check your email inbox (and the junkmail folder if you don't receive it.) An email will be sent to you with a link to click on.
4. This link will take you to a page where you can reset your password
You will then be able to log into your account with your original email address and your new password.
Let me know if this works.
Photo of UK Duke
UK Duke, Champion
  • 3321 Posts
  • 213 Reply Likes
this is a relativly common problem - you have to clear your browser history then login directly at yola.com . That will do the trick.
Photo of Prateek
Prateek
  • 3 Posts
although my password was correct but now i am happy that it is working. i have changed the password with reset key . ya email was in junk that i never thought .
Photo of Kershnee
Kershnee
  • 2087 Posts
  • 152 Reply Likes
That's great to hear Prateek. Glad to hear you got it work!!
Photo of Alex
Alex
  • 3448 Posts
  • 39 Reply Likes
i did have this problem but after about 20 go's it worked.
Photo of UK Duke
UK Duke, Champion
  • 3321 Posts
  • 213 Reply Likes
THREAD READERS:
Delete your browser history - Then log in directly as normal at http://yola.com
Photo of Prateek
Prateek
  • 3 Posts
noo that is not working buddy .
Photo of Marije
Marije, Official Rep
  • 4636 Posts
  • 237 Reply Likes
Hi Prateek,
If you think your login details may be incorrect, please send an email to support@yola.com so that we look up your info. If possible, please include your site's address so that we look up the right details.
