Problem with DNS
Hello, I was planning on updating my site tonight when I get home and wanted to know if the problem with my DNS is fixed? I'm nervouse about unpublishing it to do my updates because of the numerouse problems I've encountered thus far. I was instructed by technical support to call first and have technical support manually unpublish and the publish mysite if updates had to be made. Can some please look into this for me and let me know whether or not if it's ok for me to do this manually. My URL is www.houseofbyson.com.
Regards,
Houseofbyson
Photo of houseofbyson
houseofbyson
  • 14 Posts
Photo of Emmy
Emmy
  • 5892 Posts
  • 299 Reply Likes
Hello,
I do see that you worked with Jackie on another thread here: Error when I try to publish my site. When you asked if you should call when you need to make updates to your site, what Jackie was explaining was that it's not necessary to unpublish your site to make changes. All you need to do is go in, make changes/additions, and then click on the green "Publish to the web" button and this will apply the changes to your published site. This should work seamlessly so if you have any troubles please let us know.
Kind Regards,
Emmy
