Problem with my .gr domain extension
  • Updated 7 years ago
I have a problem with my .gr domain extension
I bought my domain (.gr) through another registrar site, not Yola, because Yola can't offer the option for a .gr (GREECE) domain. I know that I can't either transfer my domain to Yola (as I said is a .gr domain).
Please, tell me if I could point my domain directly to Yola. It will work with my .gr domain? I already have Yola Bronze.
I have taken a look at this tutorial: https://www.yola.com/tutorials/articl...
but i don't know how exactly set up 2 A records (I know how to log in to my domain registrar, then go to DNS Management page ect., but I'm not sure what to write as A records (I know how to point to your (Yola) IP).
I wrote ns1.mydomain.gr and ns2.mydomain.gr both pointed to your IP, but it wont work.. Yola gives me the message: "There was an error with setting up your domain. Please try again."
I wrote the correct words for the 2 A records or not?
Please, help! What to do?
I send you 3 detailed print screen images. Maybe you will understand better.
http://i47.tinypic.com/dcufm.jpg
http://i45.tinypic.com/x3fjx5.jpg
http://i46.tinypic.com/30w8mc7.jpg
Thank you in advance
Photo of e-italika
e-italika
  • 4 Posts
  • 1 Reply Like
  • confused
Posted 7 years ago
Photo of Laura Thomas
  • 4536 Posts
  • 211 Reply Likes
Hi there,
Yola does not have name servers, instead you must point your domain to your site by creating two A records (address records) as detailed in the tutorial you linked above. Chances are your current registrar can help you with setting up your A records if you let them know you need to A records pointing to 184.72.229.176.
Photo of e-italika
e-italika
  • 4 Posts
  • 1 Reply Like
Hi Laura,
the problem was that i had no DNS hosting.
I purchased one from my registrar and they helped me with setting up 2 A records and ... it works!
thank you again for the reply :)
