Problem with pointing my website
Hello Yola team,
I have added 2 A records with Yola's IP address on my DNS management page, and have been waiting 36 hours now to see if it can be published, but I still get " not pointing correctly" message when I try to publish my site. Can you help me with this problem, or should I contact my domain host? My domain host is Doteasy.
Photo of Donna
Donna
  • 7 Posts
  • 3 Reply Likes
Photo of Gop
Gop
  • 7473 Posts
  • 2115 Reply Likes
Hi Donna,
Can you let us know your domain name? It's possible to check the DNS records remotely.
If you want help with this then yes, your domain registrar is a good point to stop in at.
Photo of Donna
Donna
  • 7 Posts
  • 3 Reply Likes
Hi!
My domain name is mtseymourpreschool.org.
Photo of Donna
Donna
  • 7 Posts
  • 3 Reply Likes
I have just contacted my domain registrar and I have done everything correctly. I have 2 A records pointed at Yola. Maybe I need to wait for them to take effect from their end?? I will check back later today.
Photo of Gop
Gop
  • 7473 Posts
  • 2115 Reply Likes
Hi Donna,
Have checked out your DNS settings and there is one IP address that's incorrect. The www is pointing to 108.60.15.18 (ie doteasy?)whereas it must be pointed to Yola. 184.72.229.176
Both records must be pointed to 184.72.229.176
If you fix this I think you will be OK.
Photo of Donna
Donna
  • 7 Posts
  • 3 Reply Likes
Wow-you guys are awesome! I will double check that it's pointing to Yola. Thanks!
Photo of Gop
Gop
  • 7473 Posts
  • 2115 Reply Likes
Your site is now up and running I can see. Good work Donna. All in the curve?
Photo of Donna
Donna
  • 7 Posts
  • 3 Reply Likes
The Curve is up!!! :)
