Problems building site HELP! please
  • Acknowledged
How do I get my own logo on the header part of my web page? I used a template to create the site from here - but have had a logo professionally done - I can't get it to go onto the section of the page I want it to though. I am not a techie, so don't do codes etc. Any help would be appreciated. Thanks
Photo of Kirsty Tyrrell
Kirsty Tyrrell
  • 1 Post
  • frustrated
Photo of David
David
  • 465 Posts
  • 94 Reply Likes
Hi Kirsty
Open sitebuilder and click on 'style', then click 'edit banner' then 'change banner image'. You then need to click 'upload new banner' and locate your logo which will then be resized/applied.
Photo of Nazlie
Nazlie
  • 1721 Posts
  • 51 Reply Likes
Hi Kirsty
If you would like to keep the existing banner or have a banner and a logo, you may also find this tutorial helpful: How to add my logo to the banner area?
Thank you for assisting with this question, David. Much appreciated :)
Nazlie
