Problems with Digg tool
  • Solved
When I add the Digg tool to my blog post in the HTML section of the post, and click "ok" it erases it. It works when I put it outside of a blogpost but not in a blog post. Here is the code
Photo of Nathan
Nathan
  • 4 Posts
  • free
Sanja
Hello Nathan
Can you try posting your code again? This time try wrapping your code inside with <!-- your code goes here --> This helps to keep your code from being read.
Photo of Nathan
Nathan
  • 4 Posts
Sure. <!-- <script src="http://digg.com/tools/diggthis.js" type="text/javascript"></script> -->
Sorry about that
Photo of Marije
Marije, Official Rep
  • 4636 Posts
  • 237 Reply Likes
Hi Nathan - some code like the one above won't work in a blog post. Unfortunately this is a limitation of the blog post editor and I'm going to pass this onto our development team.
I'm sorry that this can't be added to your blogposts.
Photo of UK Duke
UK Duke, Champion
  • 3321 Posts
  • 213 Reply Likes
Hi Nathan,
I'm sure there is another way to 'work around' the problem you have.
i dont use Yolas blog feature to much but i have a bit of experience with social networking.
I have tested this method on my (forgotten) blog page and it works.
I'm not sure exactly what it was you were trying to do but this method would work if you wanted to allow users to 'digg' your blog post.
See here - Hexham.info
The first post 'antiques fair' has a link to digg the post at the bottom.
It has some cool extras like adding a title / description / topic and media selection.
You could also add a digg image as a link instead of the text i use,
If this is what you were trying to achieve let me know.
Lee.
Photo of Marije
  • 4636 Posts
  • 237 Reply Likes
As always, thank you for your help Lee!
Photo of Nathan
Nathan
  • 4 Posts
Sort of, I was sort of looking at putting in the top right hand corner of the post sort of like here ( http://tinyurl.com/ndenfn ). I've done that in the comments section, but I didn't like it at the bottom. Thanks for your help
