Publishing Problem
Yola site wont publish to a website that is pointing to Yola..? The DNS Management is set correctly with the two addresses set to IP : 208.75.208.172. Any ideas why this may be... Thanks, DM.
Photo of Seaview Flowers
Seaview Flowers
  • 99 Posts
  • 3 Reply Likes
Photo of Emmy
Emmy
  • 5892 Posts
  • 299 Reply Likes
Hello Seaview,
Can you tell me what your url is and I can take a look at the settings for you and help.
Emmy
Seaview Flowers
  • 99 Posts
  • 3 Reply Likes
Photo of Emmy
Emmy
  • 5892 Posts
  • 299 Reply Likes
Hello,
I have taken a look at your domain's settings, I see that you have one A Record pointing to Yola and another pointing to: 213.175.221.80, this is why the site is not publishing.
Please make sure that your A Records point to Yola only. You need to make sure you have 2 A records set up, one with the hostname "www" and one with the hostname "@" or "*". Both A records should point to 208.75.208.172 - you should do this regardless of which domain you want as primary.
If you edit the other A Record to point towards our ip address this will solve the problem.
Hope this helps!
Emmy
Seaview Flowers
  • 99 Posts
  • 3 Reply Likes
Thank you, it worked :-)
Photo of Emmy
Emmy
  • 5892 Posts
  • 299 Reply Likes
Wonderful, glad to hear it!
