Same Code WILL work on Home Page, but not on Others
Ok. Here goes. On my home page www.vizbizonline.com in the upper-left corner I have a banner which if clicked then a window pops up where customers can request a quote by filling out the form and submitting it. That is working fine. However, on the other two pages of my site- when I have copy and pasted the same code in three separate html widgets - in the same order as on the home page - the banner appears but the window does not pop up. I do not know why. Please check it out and tell me why it's working on one page, but the same code is not working on the other two.
Thank you.
Photo of Vizbiz
Vizbiz
  • 12 Posts
  • vey puzzled. Want it to work for my Customers sake and mine!
Photo of SilverX
SilverX
  • 492 Posts
  • 40 Reply Likes
Recheck that you've copied the whole code from original.
Use Ctrl + A to select them all.
Photo of Vizbiz
Vizbiz
  • 12 Posts
I did that but it still doesn't work.
Sanja, Official Rep
Hello Vizbiz
I would also check that each line of your code is broken up the same as you see on your index page. This can contribute to codes not working properly.
If you still cannot fix the problem, please send a email to support@yola.com and we can look it more closely from there.
