Font/text is highlighted on the webpage
  • Solved
  • (Edited)
Website font coming in different colours
guys my site home page has font of different colours
i have tried to delete the font[backspace]and write but it still commes in a colour
this is not a problem of setting da font ,its in white but many alphabets are coloured in pink green etc
here is a page
http://dragonballzgamesforpc.yolasite...
take a look at the text just below the promo video
Photo of SamI
SamI
  • 90 Posts
  • 4 Reply Likes
Photo of Nazlie
Nazlie
  • 1721 Posts
  • 51 Reply Likes
Hi Saml
Thank you for sharing your website link so that I could take a look at the problem you are having. I can see the highlighted text on your home page which is probably not the effect you want to have.
Is it possible that you have text copied and pasted from a word processing program such as MS Word onto your site? If you have, then this often brings along unwanted formatting that is not web friendly. It may cause your text to display incorrectly and can easily break your page. It can also cause your site to show up inconsistently in different browsers.
To avoid display and loading issues, I suggest that you paste your text into a text editor such as NotePad (in the accessories folder of your computer) and then paste it as plain text onto your Yola page. Then use the Text Editing Toolbar to format your text.
Please note that this would be the case with any browser-based text editor you might use, not just Yola. It is a universal website building problem.
What I suggest you do to fix the problem:
1. Copy the text from your published site into NotePad.
2. Go to you Yola page and remove (delete) the Text Widget with the highlighted text.
3. Then add another Text Widget.
4. Now copy and paste the text from Notepad, into the new Text Widget.
5. Use the Text Editing Toolbar (you'll see it underneath the main menu if you are inside the Text Widget) to format the text.
I hope this solves your problem. If you need more help with it, please let us know.
Thank you
Nazlie
