Site Navigation Help
I would like to add "back to top" at the bottom of all my pages- and have it be functional. How do I do this?
Also, I tried multiple times to add go to Link feature and was not successful all of the time getting that accomplished, anyone else?
Also, can anyone compare Yola Gold to SiteWit as far as cost and marketing concerned? Anyone getting all the hits they can handle just using Yola??
Photo of Beth Pettenger-Wendling
  • 2 Posts
  • sad, frustrated
Photo of Justin Lavelle
Justin Lavelle
  • 8 Posts
  • 7 Reply Likes
Hi Beth
The approach to adding a "back to top' is pretty simple. All you need to do is place an HTML widget at the bottom of each of your pages and place the following code inside the code editor when it opens:
<a href="#Top">Go to Top</a>
You could also replace the text link with an image link and set the destination as #Top
Unfortunately I can't provide you with the comparison you asked for.
I hope that I was able to help.
Justin
