Sitebuilder loads and then redirects to preview - very odd. Need help please?
Hi
Recently, I added some html code from an ad network into my site.
Ever since then, I have had trouble with the sitebuilder.
From my sites, when I click on my site, the sitebuilder interface loads and then immediately it redirects to a preview-like page, without the usual widget menu on the side or any of the save/ publish/ menu options at the top.
So I can't currently make adjustments to my site.
I can't remove this code. It's very frustrating.
I can't get rid of any html widgets - which is what I think I need to do.
It's not a browser problem. Internet explorer was working fine before this.
I need to stop this redirection and eliminate this code.
Greatly appreciate the help.
Please help.
Very frustrating
thanks
Photo of novelist75
novelist75
  • 1 Post
Photo of Emmy
Emmy
  • 5892 Posts
  • 299 Reply Likes
Hello,
Yes, when you add a redirect script it will redirect in the Sitebuilder as well. Can you please email us at support@yola.com and we can work with you from there and see if we are possibly able to locate the HTML widget that would need to be removed.
Kind Regards,
Emmy
