so what's the problem about making up a background and is it possible
  • Updated 10 years ago
I see people now with there logo or picture etc.. on there background is it possible to create your own background like in the this months featured sites
Photo of Confused.com
Confused.com
  • 7 Posts
  • undecided
Photo of Ruth
Ruth
  • 2819 Posts
  • 135 Reply Likes
Hi Confused.com. To create a personalised site like the ones that you see on the featured sites you need to make sure that you select a style from our style choices that has a customizable banner.
If the banner image can be changed, you will see a white box with an instruction placed over the default banner image.
To change the banner image:
1) Click on the white instruction box that says "click here to change banner image"
2) The file manager will open up that will allow you to browse your computer for a picture to upload.
3) When you are done, click "ok" and your own image will replace the default image
4) If the dimensions are not quite right you can fix this by choosing the "edit with Picnik" option in the file manager. Picnik is a web-based image manipulation tool that has an option for you to resize your image. When you are done, click "save to SynthaSite" and the new image will replace the old one.
Please note that the white instruction box will only appear in editing mode, and will disappear when you preview or publish your site.
