Some links will not work?
Hello all
I use the same way every time to add links,yet some work and others dont.
I highlight the text,press on links paste the url and press the little round button and so on.
And save
When i view the link,its as if ,its a link,but dosent click.
Also gone into the html,and the link is there
My site is Ramadan Daily
An(ONE) example of link,top right hand side ''He prays but he does not fast''
http://ramadan-daily.yolasite.com/day...
Thank you
Photo of ramadan-daily
ramadan-daily
  • 8 Posts
Sanja, Official Rep
Hi Ramadan-daily
I noticed in your HTML, you have this code in the text box that contains the link that does not work: <a class="tlink"> Can you try removing that and see if that makes any difference?
ramadan-daily
  • 8 Posts
Thank you for your reply.
I told out that part of the code as you said,and now it shows,there isnt a line under the text,so that didnt work
This is what is left
Islam qa
Eating out of forgetfulness in Ramadan
Sanja, Official Rep
Now.. try to re-add the process for your link again. Highlight the text you want linked, then go to the little chain icon on your text toolbar. Enter in the page or external url that you want.
Please let me know if this still does not resolve the issue. I will take a closer look at what's going on. Thanks.
ramadan-daily
  • 8 Posts
o.k.,so that worked now,just wondering if i have to go though all that each time.
The strange thing is,i add every link the same way,and it just depends which links are lucky :D
Thank you so much for your help
Fatimah.
Sanja, Official Rep
Normally, you should be able to use the link icon to create your links. However, in your case, I'm wondering if you had copied and pasted from an external source. By doing that, it creates unwanted formatting in your site builder. IF you do copy from an external source, please be sure to paste inside Notepad first to strip away any inherent formatting. Then copy and paste into your site builder.
ramadan-daily
  • 8 Posts
ohh o.k. then,i will remember that.
Also wanted to ask about,lets say fonts and changing colours and so on,
i highlight the text,and press text'normal' and is dosent seem to change,also colours and so on
Sanja, Official Rep
Can you please send an email so that I can see what's going on? Email: support@yola.com and ATTN: Littleus
