SWF Flash FATAL problem
  • Updated 5 years ago
  • Not a Problem
SWF Flash FATAL problem. check picture
Photo of Ricardo Silva
Ricardo Silva
  • 3 Posts
  • frustrated
Posted 5 years ago
Photo of Jen
Jen
  • 206 Posts
  • 24 Reply Likes
Hello Ricardo,
In order to assist you we'll need to gather a little more information about the problem or question you have.
Please provide:
* the site with the problem
* the page with the problem
* the widget you are using
If you can also give us an idea about what you are trying to do, the steps you have already tried, and what happened when you tried them, it will help us to assist you better.
We look forward to hearing from you.
Ricardo Silva
  • 3 Posts
all my sites have this problem with this one SWF.
including
www.dronesportugal.com
www.limpezaterrenosagostiho.com
www.dronesportugal.yolasite.com
etc
the page i tryed every page, including the main page.
the widget is the SWF from yola, you can download the file from www.dronesportugal.yolasite.com
i just upload it to yola and the rest is on te picture above
Photo of Jen
Jen
  • 206 Posts
  • 24 Reply Likes
Hello Ricardo,
Thanks for your reply.
I checked the files on your site, one is a .rar file which won't play in the Flash Widget.  It looks like you're trying to upload a flash player which is not required.  The Flash Widget will use the flash feature installed on your computer or browser.
I downloaded the .swf file to my computer, and it can't be opened.  'IO Error' is the short form of 'Input/Output Error' and means that the loading itself is not possible, so it appears that there is an issue with the .swf file itself.
I'd suggest contacting the file provider for a new version of the .swf, then add it to your page using only the .swf and the Flash Widget.
Please remember your inquiries are always welcome.
Ricardo Silva
  • 3 Posts
thanks. the flash player is only to view in my computer, no need for the website. if the .swf opens on that player it should open on website also...
Photo of Jen
Jen
  • 206 Posts
  • 24 Reply Likes
Hi Ricardo,
The .swf file you uploaded won't open because there's something wrong with it.  It won't work on any flash player.
Please feel free to contact us again if you need any further assistance.
