swf in IE problem
  • Updated 10 years ago
the swf files i use play in firefox but not in explorer. any ideas why? http://www.hexham.info
Photo of UK Duke
UK Duke, Champion
  • 3321 Posts
  • 213 Reply Likes
Photo of Marije
Marije, Official Rep
  • 4636 Posts
  • 237 Reply Likes
Hi lee,
Could you post a link to a particular page where you are experiencing this problem? I checked the home page and everything displays fine in both browsers for me.
Photo of UK Duke
UK Duke, Champion
  • 3321 Posts
  • 213 Reply Likes
Photo of Marije
  • 4636 Posts
  • 237 Reply Likes
Hi lee,
Could you let me know where you got the code to add the swf file?
We have a post that has more information on adding swf files to your page: http://getsatisfaction.com/SynthaSite.... Please can you check whether you are missing any of the settings described in that post.
Photo of UK Duke
UK Duke, Champion
  • 3321 Posts
  • 213 Reply Likes
its from aleo software flash intro banner maker.i read the article you suggested. Should i just use this code instead? will that allow the links etc. of the object to work correctly (i.e. if you clcik the main it links and if you click the site icon it goes to my site. I dont know if this is from the file or from the html. Thanks in advance
Photo of Marije
  • 4636 Posts
  • 237 Reply Likes
Hi lee,
I just tested your code and made a slight change, this is what it should be:
<object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" codebase="http://fpdownload.macromedia.com/pub/..." width="499" height="125">
<param name="movie" value="resources/dadsfinalad.swf" />
<param name="quality" value="high" />
<embed src="resources/dadsfinalad.swf"
quality="high"
type="application/x-shockwave-flash"
width="500"
height="125"
pluginspage="http://www.macromedia.com/go/getflash..." />
</object>
I didn't realise that there was a missing link to the swf file (it's listed twice in the code). Can you try again and let me know if it works for you?
Photo of Marije
  • 4636 Posts
  • 237 Reply Likes
I forgot to tell you to ignore <!-- and --> those are there to stop the code from being interpreted :)
Photo of UK Duke
UK Duke, Champion
  • 3321 Posts
  • 213 Reply Likes
so value and emeded source = "resources/xxxxxxx" i'm sure i tried that in the first place, is there sometimes a delay till you update where the flash doesnt show up? anyway, many thanks for your help - your all doing a great job -
Photo of Marije
  • 4636 Posts
  • 237 Reply Likes
There is a delay of a few seconds - I guess it could be affected by the size of the file. Remember to include the folder name if you've put the swf file into a folder - resources/folder/file.swf.
