Tech Question..Please Help ASAP..
  • Updated 7 years ago
Hello Everyone...Quick question...Please take a look at my site... http://unlimitedwealth.yolasite.com/
I would like to move the red arrow and opt-in form closer to the video image...So it does not have such a big gap between them..How would I go about doing this? Thank you...
Photo of unlimitedprosperity72
  • 4 Posts
Posted 7 years ago
Photo of Gop
Gop
  • 7473 Posts
  • 2115 Reply Likes
Hi,
I think you have added your Right hand content as individual components rather than a block with data enclosed?
The problem here is that you have only about 10 pixels of space that has been used as margins between the left and the right containers. You would in that case need to move the left margin of every component by 10 pixels and that really is a tiny piece of real estate.
If you just moved your red arrow then it would not be centre aligned with the rest of your right hand content and may look really strange to you.
I'm happy to give you some direction on how to do this so let me know if you still wish to go ahead or think of another alternative in design?
Are you comfortable with HTML and CSS ?
  • 4 Posts
Sure? Please send more info...
Thank you,
Chris
Photo of Gop
Gop
  • 7473 Posts
  • 2115 Reply Likes
Hi Chris,
I see that you have changed the design so I'm guessing that your request is now redundant?
