Testimonials, guestbooks and calanders - help!
Is there any way of getting a testimonial or guestbook on the free site? Also, a calender when you can say what dates you are free etc?
Any help would be much appreciated!
Photo of Brooke Nolan
Brooke Nolan
  • 1 Post
  • confused
Photo of Laura Thomas
  • 4536 Posts
  • 211 Reply Likes
Hi Brooke,
Absolutely! You can add both a calendar and a guest book to your site via Widget Gallery. Here's how:
1. Drag and drop a Widgetbox Gallery Widget onto your page.
2. A dialog box will open, search for "guest book" or "calendar' to see all the widgets available.
3. Choose the widget you would like to use on your site, and customize the settings.
4. Click on the "Get Widget" button and it will be saved and added to your page.
5. Save and preview your page to view the widget.
Alternatively, you can use a service like the Google calendar or calendars.net.
