Text alignment not running true
Edit site with FF 6.0 all cache cleared. etcetera.
There are five images placed within a series of column dividers. The titles are below and centre-aligned under each image. the text is displaying as Right aligned.
The issue of spacing is a separate one and will be taken care of but this doesn't explain the mis-alignment of the text. This isn't showing on preview although the text mis-alignment is
http://phuphamanorchids.yolasite.com/... is one of the five examples.
Wondering how I can correct this please.
Photo of Gop
Gop
  • 189 Posts
  • 54 Reply Likes
Photo of David
David
  • 465 Posts
  • 94 Reply Likes
Hi
I can't help with the misalignment but you are showing different fonts, 1, 4, and 5 are not the same as 2 and 3
Photo of Gop
Gop
  • 189 Posts
  • 54 Reply Likes
david thank you for the heads up on that. Good eyes
Sanja
Hello Gop,
The reason why there is misalignment with your text is because it's actually your photos that are not centered. If you click on the "Edit" link and select the center option, this will align your photo nicely over the text.
This should hopefully resolve the issue.
Photo of Gop
Gop
  • 189 Posts
  • 54 Reply Likes
Sanja it does. That is a great solution and I'm relieved that you were able to give this fix to me. Thank you very much.
Sanja
My pleasure! I'm glad that it was an easy fix :)
