Text Problems (Need help ASAP)
  • Updated 10 years ago
  • Acknowledged
Archived
This conversation was archived and is no longer visible to community members. The community moderator provided the following reason for archiving: out of date
I dont really like the new text editor. I cant resize/recolor/Add link or anything and i need help to contiune editing.
I have already tried clearing my browsers cookies and what not but it still did not work!
Thx
Pitfall
Photo of Pitfall
Pitfall
  • 44 Posts
  • anxious
Sanja
Hi Pitfall
There appears to be a bug with the text editor. There is a way around it though. Please read Marije's (A Yola rep) advice as given on this thread:
If you add text to your page and select only the text (don't select any spaces before or after the text), you will be able to format the text using the text toolbar.
If you add text to your page and select all the text (using 'select-all') or sweep the text with your cursor and include a space at the end of the text, you will find that you are unable to format the text using the text toolbar.
Please let us know if this does not resolve the issue for you.
