Two Column Layout Help!?
If you create a 2 column layout, is there a way to make one on a second page the same exact size without keeping the default size?
Photo of Donald
Donald
  • 2991 Posts
  • 37 Reply Likes
  • fine
Sanja, Official Rep
Hi Donald,
My suggestion would be to use "Save Page As" under your Save button. This will replicate your page and everything on it, including the dimensions.
Does this help?
Photo of Donald
Donald
  • 2991 Posts
  • 37 Reply Likes
I'll try it when i get the chance but it sounds like it'll work. thanks
Photo of Diane
Diane
  • 90 Posts
  • 10 Reply Likes
Hi Donald-
You can also try using our Change Layout function to set the page layout that way. It will default to the same settings each time, though images may alter them if they're wider than the default setting.
Diane
- Graphic Designer | Yola, Inc.
Photo of Kershnee
Kershnee
  • 2087 Posts
  • 152 Reply Likes
I agree with Littleus, use the "Save page as" option.
Here are the full steps if you need them:
1. Navigate to the page you want to copy
2. On the Yola toolbar, click on the down-arrow next to the "Save" button.
3. Choose "Save Page As"
5. The "Save Page As" dialog box will pop-up asking you to name your new page, (and give you the chance to change the page heading, and decide whether or not to include the new page in your menu).
6. Click "OK" and you're done. The newly created page will now appear up in the Page drop-down arrow of page choices, so you can go back to it again if you chose not to include it in your menu.
