Urgent help needed- Problem after DoS attack on Yola and IP change
After the DoS attack on Yola, I changed the IP address to the new one, as per Yola's indication.
I have two published sites: www.new-idan.org, and www.robbinsmadanesisrael.co.il.
With the first one, everything is OK after the IP change.
With the second one, I have a very strange problem. In my personal laptop, I can surf the net and perfectly see the site. In any other computer, even at friends' computers, I can't see the published site. It gives an error.
I need urgent help with this, I'll appreciate your prompt response
Photo of ezequiel madanes
ezequiel madanes
  • 2 Posts
  • frustrated
Photo of Marije
Marije, Official Rep
  • 4636 Posts
  • 237 Reply Likes
Hi Ezequiel,
Both of your sites are up for me:
The change may just be propagating through the internet. You can also try clearing you browser's cache: http://www.google.com/support/account...
Don't worry, it will be up soon!
Photo of kinopurdubal
  • 1 Post
Thank you Marije!!!!!! Everything is now working perfect.
I have another question, I'll appreciate your help:
Can I add a link to the videoclips (all are swf's inserted as Html objects)? It will be great to have that option
Again, thanx a lot for your help
Photo of Marije
  • 4636 Posts
  • 237 Reply Likes
Hi kinopurdubal - you can find information on how to add a swf file on this link: http://www.yola.com/customer-support/...
